newbie question about DIY version TPS Tip in
Hello, someone can tell me if with the DIY version I could adjust the rich condition before release the gas pedal? In my old setup with Crome I couldnt resolve this problem. Thanks
Why would you have the same problems with tip-out in eCtune when you have this problem now in crome? The software is totally different, so the change that the eCtune gives the same problems as crome is nearly 0. What problems do you have now? If you are more presize, maybe we can give you an exact answer.
Well, in Crome I need to adjust 1500rpm line and add more columns to avoid the rich condition when I released the gas pedal, the lambda goes to 12-11-10-9-8-9-10-11-12 (delay before fuelcut)... and when I press pedal @ wot the same problem (not so high becouse I could adjust with throttle tip-in). So when I saw the diferences between DIY and PRO ectune I saw that TipIn control is not implemented in DIY. So Im interested to know what is this difference between the two version, and if DIY I could adjust this tps tip in/out Thanks
