Cell locked up
SPoole
Cell locked up
Post by SPoole »
The 2000 rpm/ B19 cell in the high map is stuck. Anyone else have this issue or is it my laptop?
EBCBase.cal
(8.17 KiB) Downloaded 256 times
double click and change the value
SPoole
Post by SPoole »
That worked. Thanks
SPoole
Post by SPoole »
I noticed last night that it seems to be that whole row that has to be changed manually. Do I have something set wrong?
-setting -general -increase/decrease settings
I have this also. especially at lower numbers but I also had this once in higher numbers. Calvin, what are the best settings to avoid this? I havent figured out what is best...
some time the perctage/fuel value switch.. the value added is to small to increase the column multiplier... depends... the +/- won't work right? you can see what the value is... if it more or less then switch over... then increase the FV added or % change
