Problems with ectune on vista.
ovrbst
Post by ovrbst »
I just installd ectune on my new laptop which has vista as the operatng system.everything installed correctly and i got my new lic from calvin and installed that aswell.i started making a basemap for my setup and when i was finished i got the error at the basemap creator, \"unhandled exception has occured\".i hit continue and now the basemap i just crated is the but there is a big red x in the graph box.i did so searching on this but i could'nt find too much alltho im still searching.any help would be appreciated. Im also thinking it might be the .net framework on this laptop.
could be every related to .net frame work.. if you disabled UAC all should be good
ovrbst
Post by ovrbst »
calvin wrote:could be every related to .net frame work.. if you disabled UAC all should be good
uac is disabled and im still getting the error and the red x.here is the error messege See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at d&#134;&#147;2&#139;�d9ftf&#152;wg&#147;wes.w&#159;&#145;&#153;5&#142;cj&#142;1xqk&#154;1&#151;2o.&#139;&#153;&#151;&#135;&#135;&#137;&#154;&#150;&#156;&#137;() at d&#134;&#147;2&#139;�d9ftf&#152;wg&#147;wes.w&#159;&#145;&#153;5&#142;cj&#142;1xqk&#154;1&#151;2o.OnPaint(PaintEventArgs ) at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs) at System.Windows.Forms.Control.WmPaint(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.UserControl.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- eCtune Assembly Version: 0.0.2.2 Win32 Version: 0.0.2.2 CodeBase: file:///C:/Program%20Files/eCtune/eCtune.EXE ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- startup_lib_net_2_0 Assembly Version: 2.0.0.0 Win32 Version: 0.0.2.2 CodeBase: file:///C:/Program%20Files/eCtune/eCtune.EXE ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Management Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll ---------------------------------------- Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Security Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Security/2.0.0.0__b03f5f7f11d50a3a/System.Security.dll ---------------------------------------- System.Web.Services Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll ---------------------------------------- System.Deployment Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Deployment/2.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll ---------------------------------------- Interop.MTSSDKLib Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Program%20Files/eCtune/Interop.MTSSDKLib.DLL ---------------------------------------- eCtune.XmlSerializers Assembly Version: 0.0.2.2 Win32 Version: 0.0.2.2 CodeBase: file:///C:/Program%20Files/eCtune/eCtune.XmlSerializers.DLL ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
code is encrypted can't tell where that happens.... hit me on AIM or SKYPE or MSN... then i can debug it.. but it's def something with your laptop / windows
ovrbst
Post by ovrbst »
calvin wrote:code is encrypted can't tell where that happens.... hit me on AIM or SKYPE or MSN... then i can debug it.. but it's def something with your laptop / windows
whats your msn contact calvin.
calvin_junk @ hotmail.com I'm out of office till late... drop me an email so i can send you the new version
ovrbst
Post by ovrbst »
Im still waiting for an email back from you.What i did in the meantime was,uninstalled ectune and .net framework v3.5 \"sp1\"that was on the comp? which i thought was causing the problems.i reinstalled ectune and it promted me to get .net framework and i down loaded the 3.0 version after that i made a new basemap and it did the same thing.Also when i run force update it takes a long time like 5 min and when i start up ectune it says to \"run force update within a week cause the version i have is gonna expire\"?Im about to reformat this comp and put xp pro on it but i dont want to i kinda like vista. What version of .net framework should i have with vista? Calvin my email add is [email protected]
i got your mail but i can do so much in a day.. if you return the setup it installs everything you need
ovrbst
Post by ovrbst »
calvin wrote:i got your mail but i can do so much in a day.. if you return the setup it installs everything you need
well i uninstalled .net freamework and reinstalled ectune.when i start the ectune preogram i get this message, "unable to find assembly'ectune,version=0.0.2.1,cultur=neutral,publickeytoken=6ab39c1170c85a55'.
did you use the setup file and ran the force update after? i don't think the force update runs... setup is a old version correct 0.0.2.1 but should auto update after install to 0.0.2.2 r2
ovrbst
Post by ovrbst »
calvin wrote:did you use the setup file and ran the force update after? i don't think the force update runs... setup is a old version correct 0.0.2.1 but should auto update after install to 0.0.2.2 r2
i ran the one with the .net framework install on it.and i also tried the other one that does'nt have .net framework but it will redirect you to the .net framework website.I must be doing something wrong...Is there a special way to install ectune on a vista operating system?
sj-performance
Post by sj-performance »
reinstall it, go to program files,right click ectune,click on compatibility run as windows xp and make sure the program is run as admin.try that
I don't use compatibility for my Vista and works flawless!
ovrbst
Post by ovrbst »
well im at the point where it wont even install properly.i get these errors..webupdate failed with error:there is an error in xml document (1,304)..Then it pops up this one.. \"lock system\" native protection system cant find a valid version of a protected .net assembly: ectune,version=0.2.1, culture=neutral,publickey token=6ab39c1170c85a55 Now everytime i try to do a force update it takes like 10 minutes, then it pops up thos errors. any help would be apreciated.
ovrbst
Post by ovrbst »
calvin wrote:calvin_junk @ hotmail.com I'm out of office till late... drop me an email so i can send you the new version
Is the version you were gonna email me different from the one i can dl off here?im still waiting for your email..
