FTL/Anti-lag doesn't work with IGN cut only
Minor Threat
Been playing with anti lag/FTL lately, having some small issues. When I have the rev limit set to IGN cut only, I can't get FTL/anti lag to work the car will just rev to the normal limiter, it does however seem run differently at the 3000rpm range (where I set the FTL limit), almost like it's trying to pull timing and add fuel, but I can still easily rev past that point. If I enable both fuel and ign cut, then it works fine I get a few pounds of boost, some pops, etc and it cuts out at 3000rpm (where I set it) Also, there seems to be some sort of bug in the anti lag settings. The retard ignition control enable button is greyed out, and if I set the ign retard it checks itself, but if I then select another parameter and then go back in it will be unchecked again. I've tried getting it enabled, saving the cal and then going out and back in again and it does not say that the cal has been modified at the bottom. Thoughts?
BlindFashion
Re: FTL/Anti-lag doesn't work with IGN cut only
I'm having the same exact issue(s)Minor Threat wrote:Been playing with anti lag/FTL lately, having some small issues. When I have the rev limit set to IGN cut only, I can't get FTL/anti lag to work the car will just rev to the normal limiter, it does however seem run differently at the 3000rpm range (where I set the FTL limit), almost like it's trying to pull timing and add fuel, but I can still easily rev past that point. If I enable both fuel and ign cut, then it works fine I get a few pounds of boost, some pops, etc and it cuts out at 3000rpm (where I set it) Also, there seems to be some sort of bug in the anti lag settings. The retard ignition control enable button is greyed out, and if I set the ign retard it checks itself, but if I then select another parameter and then go back in it will be unchecked again. I've tried getting it enabled, saving the cal and then going out and back in again and it does not say that the cal has been modified at the bottom. Thoughts?
- Garrett
which rom version?
- Garrett
use 0.062Minor Threat wrote:0.0.2.2r2 v0.0.61
- Garrett
make your updates
stenseltizm
I also don't have 0.0.62 and have this same check box issue as well as some weird issues with fts I'm trying to track down. Where can I find this update? I always run Force Update but it has never found any updates, so I download the installer from the top sticky in this forum. The release notes are labled as 0.0.61Garrett wrote:make your updates
- Garrett
if you don't have the last version use 0.060 it work good
Minor Threat
- Garrett
export your cal, import your calMinor Threat wrote:I can't change my basemap versions.
Minor Threat
- Garrett
only to reupload the calibration
