Disable closed loop at idle only
greasemonkee
Post by greasemonkee »
Before I spend an hours worth of idling and fuel trying to attempt this, has anyone successfully disabled closed loop at idle only for larger injectors?
at idle only? i disable it full time
BlindFashion
Re: Disable closed loop at idle only
Post by BlindFashion »
greasemonkee wrote:Before I spend an hours worth of idling and fuel trying to attempt this, has anyone successfully disabled closed loop at idle only for larger injectors?
I'd like to see this function to if possible.. The car has to idle around 13.2:1 (b16/1000cc precision) but with the closed loop on it wont do it. and then it idles like crap.
