chip burning
chip burning
r u or r u not able to burn chips so u dont have to run with a laptop all the time or run off the emulator.to be able to burn a chip or chips is important and a necessity.What if laptop fails or batteries in emulator die.what if?My laptop has a mind of its own at times and my battery holds no charge so when my power converter starts wiggin my laptop dies and so doesnt my car until i can get my laptop up and running.People need to burn chips to put in their ecu.If this is something being paid for then boundries should be almost limitless minus some frailities. Kuriosity cilled the kat
The laptop does not need to be plugged in once you've tuned it. Just the emulator with the ECU. I suspect at a point the EMU may be available in a board that can be installed inside but I'm not sure and I don't speak for moates. Maybe he can comment on that. The emulator batteries are good for about 10 years. -Michael
back from the dead.......my question is how can i burn a chip so that i can take the emulator out?i have a good base tune for my car thanks to Jd.can the dataloging program be up dated to were i can burn the chip for my self?i am willing to pay for it if i have to.shurelly you could send or make a up date to were we could do this.i would like to do this so that i DONT loose the tune i have now.i want to move back to the ecu program that i had,at least until you get all of the bugs worked out PLEASE.
Burning a chip wont be possible unless you a licensed tuner. As a DIY user, the emulator will have to be perma installed.Larry T wrote:back from the dead.......my question is how can i burn a chip so that i can take the emulator out?i have a good base tune for my car thanks to Jd.can the dataloging program be up dated to were i can burn the chip for my self?i am willing to pay for it if i have to.shurelly you could send or make a up date to were we could do this.i would like to do this so that i DONT loose the tune i have now.i want to move back to the ecu program that i had,at least until you get all of the bugs worked out PLEASE.
ok if i have to do that then do you have an emulator that has been returned or repaired that i can buy for a cheep price?i purchased the emulator that i have now from you.good buesness is return buesness........xenocron wrote:Burning a chip wont be possible unless you a licensed tuner. As a DIY user, the emulator will have to be perma installed.Larry T wrote:back from the dead.......my question is how can i burn a chip so that i can take the emulator out?i have a good base tune for my car thanks to Jd.can the dataloging program be up dated to were i can burn the chip for my self?i am willing to pay for it if i have to.shurelly you could send or make a up date to were we could do this.i would like to do this so that i DONT loose the tune i have now.i want to move back to the ecu program that i had,at least until you get all of the bugs worked out PLEASE.
No...he was talking to mecalvin wrote:from me?
