Aluminum cleaners
Aluminum cleaners
Do you guys know any liquid product that cleans heavy grime/oxidation from a bare aluminum? like trans case and engine blocks. Using sandpaper and a wire brush manually sucks. I can't find any at my local parts stores. I want to be able to just spray some cleaner, let it sit for a couple of mins, then rinse.
if you can find a heavy duty degreaser it works great thats what i use from my work we have bags its like a 1part degreaser to 50 parts water this stuff is beyond consentrated. Burns to the touch without gloves or dilution its made by kay cleansing products. Or you can get some aircraft paintremover.
The BEST thing that I ever found to clean blocks: I used it to clean this block to ass you see in the pic below:
I used 1 gallon of turpentine (paint thinner) mixed with one quart of acetone. put the engine in a nice large catch pan... and use a paint brush... don't do any work.. just brush starting around the top, and slowly work your way down.... the block comes SHINY clean with ZERO effort... just dip the brush, and slop it on. That's it. Cheap, and EFFECTIVE!
Maybe... I don't see why not.... cause this motor I got was in a barn for a few years before I bought it and cleaned it like this... I was out of spray cleaners (which are mainly acetone and xylene, which are more expensive and I ran out) so I tried the acetone I had.. and was amazed.... there was no oxidation to be found after the simple cleaning... maybe a toothbrush, but I dunno if you need to work tat hard honestly =)james25 wrote:Nice! turpentine and acetone I can find at home depot. I'll give it a shot. It cleans oxidation too?
If you are using ACETONE, make sure you were GLOVES (that can handle how corrosive that shit is) and dont get any on your skin.
correct; I use the nice blue gloves from the snap-on truck.. not snap-on brand, but the good ones (can't remember brand, but I can use the same set of gloves for about 3 weeks)xenocron wrote:If you are using ACETONE, make sure you were GLOVES (that can handle how corrosive that shit is) and dont get any on your skin.
Hope you guys are wearing thick gloves that acetone can't penetrate. Gloves in general open the pores in the skin making it easier for the solvent to get in the blood. Eyes can absorb a lot of vapor too. I'd certainly wear a good charcoal respirator if I used that. Castrol superclean would make the block look new, just with a lot of these harsh chemicals, they promote corrosion and the chemicals won't ever come out no matter how hard you wash.
