BUg booscut enable check box
I'm reporting an own bug :D fixing it later and release an update.
Yeah! I had a retune yesterday. Because this guy had a pretty old version I decided to make a new bin. It kept fuel cutting at 5psi, even when I switched boostcut off. I couldnt get this strange fuel cut away so I took his old bin and retuned him with that one. Too bad that he had bad fuel so an half hour later we were finished. Fried piston.....
Is this only when you touch the box? I didnt have this problem at all, but then again I didnt mess with it at all.
if it's enabled and you disable it you cannot enable it anymore
Gotcha.
fixed in r7
confirm fix pls
b20beast
Post by b20beast »
I enabled, disabled and re enabled works fine
