no change in fuel
vtecmangr
no change in fuel
Post by vtecmangr »
i ended up with conectivity issues and having other more serius trying to datraloging my first bin and it went realy lean i riched it up and i got nothing still lean setup 650cc precision injectors 9.1 cp's eagle rods gsr engine plx m300 running 18psi on 4th gear ang got 15afr :? hopefully the engine is still running like before here is the bin
proto.cal
(8.18 KiB) Downloaded 277 times
elevation
Post by elevation »
Dude, Your gonna blow yor setup sky high. Tune your vac columns first, That map is not going to support 18 psi and 15afr At Any boost is a no no.
vtecmangr
Post by vtecmangr »
you saying that the boosted part of the map is not enough? because i added so much fuel to start from the safe side and i was very surprised it was too lean
vtecmangr
Post by vtecmangr »
71 views and no answer?
You got an overall fuel trim of -100%... What do you think does that to your AF?
how did you create your base map? Did you enter a fuel offset of e.g. 45 or 60. start let car warm up and then decrease the offset until your idle afr is good?
