still locked out after update
borat
Still having the same problem from this thread http://forum.ectune.com/viewtopic.php?t=1686. I think this all started because I changed my clock settings earlier today to see if that would unlock ectune so I could datalog on my way home (having lean issues). I set the clock back to the right times, ran force update, it says it updated to r7, but still gives me the \"Lock System\" dialog box when I try to run the program. Things I have already tried: 0. Made sure my clock settings were correct, still locked 1. Force update, still locked 2. Uninstalled, deleted ectune directory from program files, reinstalled (it automatically does force update on reinstall), still locked 3. Uninstalled, searched HD and registry for any instances of \"ectune\" or \"in4tec\", removed any files or registry keys, reinstalled, still locked Help!
- error.jpg (23.86 KiB) Viewed 5054 times
Re: still locked out after update
I will remain locked to which date did you change it?borat wrote:Still having the same problem from this thread http://forum.ectune.com/viewtopic.php?t=1686. I think this all started because I changed my clock settings earlier today to see if that would unlock ectune so I could datalog on my way home (having lean issues). I set the clock back to the right times, ran force update, it says it updated to r7, but still gives me the "Lock System" dialog box when I try to run the program. Things I have already tried: 0. Made sure my clock settings were correct, still locked 1. Force update, still locked 2. Uninstalled, deleted ectune directory from program files, reinstalled (it automatically does force update on reinstall), still locked 3. Uninstalled, searched HD and registry for any instances of "ectune" or "in4tec", removed any files or registry keys, reinstalled, still locked Help!
