Can't open two instances of eCtune
2bfi
Post by 2bfi »
Not sure if this is an error, but since the latest update, I can't open 2 instances of eCtune. When attempting to open the 2nd eCtune, I get the following error: Image When adjusting values, I like opening two instances of eCtune to compare the starting and adjusted graphs.
I don't think it's possible with the app... take a few screenshots... that will work good.
Synoptic
Post by Synoptic »
try not to be datalogging with the first instance or not have the wb setting enabled first, then open second instance.
correct.. it is since the last update. i'll disable debug and do an update forgot a flag on
force update again.
2bfi
Post by 2bfi »
I just did a force update and now eCtune won't start. It flashes a window really quick then as if nothing happened. Force updated again and rebooted, still the same. Tried loading it again to catch the window. It flashes \"Program too big to fit in memory.\" Did a clean install and still the same thing.
fixed file got corrupted after upload
2bfi
Post by 2bfi »
Yes, it's alive! I can also open two instances of it.
