Problems with secondary Lean Protection
I've had my #1 lean protection set for a while now with no problems. I went out to tune yesterday and decided to make a \"stepped\" lean protection (From 0-5 <13, from 5-on <12.3). As soon as I went driving, after 2 grand or so with very little throttle, it was cutting ignition. Load was probably around 400mbar at very low throttle. I turned off secondary Lean Prot and it went away. Playing with the settings doesnt change anything...
I have had this issue for a while now too, I was told i was user error wayyy back when lean protection was first added, but I still dont know what im doing wrong.
i need logs and cal file.. so i can see what u mean.. 0-5 psi?
logs and cal to see this problem
