ITB> First Tune - Help ! TPS INDEXING BUG !
Chris_rai
Post by Chris_rai »
hi i'm going with my first attemp to make all thing to work. Ectune works fine, emulator is connected, hulog too, and my LC1 wired to the com port. Engine starts, runs on idle, just playing with + and - to set the AFR at approx 13-14 ( columns 0 and 1 ), runs fine, and after 2-3 mins it will shutt off ( injector cut ? ) Fuel & ign with TPS indexing hi cam only iacv just plugged on the engine harness Help thanks
eCt.base273.cal
basemap
(8.19 KiB) Downloaded 271 times
Chris_rai
Post by Chris_rai »
it seems to be ECT related ? the ECT rise to 65° and cut... the car wil re start and cut...
Piv
Post by Piv »
Hi Chris, I'm french if you want any help you can contact me [email protected] and we try to sort it out, I got basemap for ITBs :wink:
Chris_rai
Post by Chris_rai »
if TPS indexing is on, the car dies if ECT> 65° and will not restart. It will restart on MAP indexing ! so ?
Which ROM version? I´m keeping an eye on this, as I have an ITB tune coming up! /Allan
Piv
Post by Piv »
Try the 62 Rom version and disable the fuel cut as well Parameter/fuel et ignition setting/fuel cut settings Hope it helps :wink:
Chris_rai
Post by Chris_rai »
cal
eCt.base273.cal
(8.19 KiB) Downloaded 241 times
Chris_rai
Post by Chris_rai »
log
idle cut.elf
(668.58 KiB) Downloaded 258 times
Chris_rai
Post by Chris_rai »
Piv wrote:Try the 62 Rom version and disable the fuel cut as well Parameter/fuel et ignition setting/fuel cut settings Hope it helps :wink:
I can't choose the rom on the pro version ?
