R9 and much slower datalog, more CPU usage, lags
darkb16a1
Hi, with the new R9 version I noticed to have two problems. 1) Realtime update does not seem to work properly, already discussed in different topic so just a quick note here 2) Datalog rate is much lower than with previous R8 which was working flawlessly for me. When using the R9, the rate of datalog especially in the \" Display\" window the values refresh only about 2 times per second, with the R8 this was at least 5 times per second. Also, when I make a change in the fuel tables - for example select 5x5 cells area and press Ctrl+Up to add fuel 3 times, the whole program just freezes for 1-2 seconds, sort of a lag, and then continues to work. I know I am supposed to post .cal and .log file and I will do that as soon as possible, but I just wanted to let the responsible guys know that there is an issue worth analysis. Will get back to you with log files.
All problems persist, my CAL and LOG files are posted in a different topic: http://forum.ectune.com/viewtopic.php?p=17166#17166
