Need some help to get boosting!
b20beast
Post by b20beast »
Hi everyone, i thought my wideband was dead. It wasnt. I started on a ectune basemap, added 50% fuel across the entire map, and arf began to show on the scale. Heres the run down of my setup 880cc Precision Injectors 225Walbro Pump T3 T4 60Trim Turbo Stock B16a Motor NGK Copper 7 PLUGS 28THOU GAP I create a new basemap, New Injector Size - 880cc Injector Battery Offset - Precision 680cc Car Idles with a Injector Offset about 25 Boosted 10 Cols Boost Cut 10psi Boost Fuel 180% Boost Retard 1.25* Race Map B16a Map Car Idles Well, but BREAKS UP BAD in boost. So bad, the car wont accelerate. Arf in boost is 12.5-11.3
b20beast
Post by b20beast »
i think its dead i re calibrate it and it gone off!
Make sure the car is warm when you set the battery offset with no accesories on. Did you make sure to turn off stock Ign corrections? Thats under parameters.
b20beast
Post by b20beast »
ckretvix wrote:Make sure the car is warm when you set the battery offset with no accesories on. Did you make sure to turn off stock Ign corrections? Thats under parameters.
Not battery offset injector Offset FV also checked disable ign corrections
