Why does my datalogs show VERTIAL Lines?
b20beast
Post by b20beast »
Im not sure what is happening But when i replay a datalog, i get VERTICAL lines
offset.cal
MAP
(8.19 KiB) Downloaded 270 times
ba_16042009_2134.elf
LOG
(455.81 KiB) Downloaded 277 times
b20beast
Post by b20beast »
Here is a scr shot
pic
pic
elevation
Post by elevation »
ground problem?
b20beast
Post by b20beast »
grounds seem fine double checked them
Synoptic
Post by Synoptic »
Number of sample per second is too low.. so you do not datalog enough.
b20beast
Post by b20beast »
sample update delay is 4 stack size is 100 min samples is 50
i'll show u later ecu is reseting or u using a bad datalog cable(nokia perhaps)
