Accord F22 Turbo
- Piv
Accord F22 Turbo
Honda Accord 2.2i SOHC (F22Z2) Wiseco 8.8:1 Forged Pistons CAT Power Super H Beam Forged Rods ARP Headstuds Turbonetics T3/T4 Turbo V trim stage 2 .48 51 Lbs/min Turbonetics Evolution wastegate Turbonetics Raptor BOV Apexi Power Intake Treadstone cast manifold Treadstone TR8 intercooler Treadstone 2.5\" Intercooler piping Custom 2.5 inch stainless downpipe kit HRC Racing 255lph Uprated Fuel Pump HRC Fuel Pressure Regulator AEM Tru Boost Contoller 440cc Lucas Injctors Iridium Spark Plugs 3\" Decatted S/S Exhaust Remap before with crome by another Tuner Remap now with eCtune The customer came because he wasnt too happy about the driveability on decelaration and had problem on cold start as well with crome but apparently the power was ok He's more than happy now as the cold start is not a problem anymore, the driveability is much better and the power a bit better ^_^ Thanks again eCtune, it was the first time I remap a F22 and I was quite impress about the torque it made
You can see the difference before and after (crome VS eCtune) 7psi 10psi 12psi
- TurboF22 small.JPG (73.96 KiB) Viewed 47606 times
- TurboF22_0006small.JPG (74.62 KiB) Viewed 47607 times
- TurboF22_0007small.JPG (74.74 KiB) Viewed 47607 times
- VTEC Inside
Excuse me but how can I see the difference? p.s. Sorry after I replied the pictures came up. Looks good over Crome
- Piv
On each graph you got 2 differents curve The lowest one is the crome oneVTEC Inside wrote:Excuse me but how can I see the difference?
Whaxola09
Accord F22 Turbo
It should be very possible to turbo that car. The problem is going to be money because I dont think you can do it on the cheap. But then I dont think you should do any major mods like a turbo on the cheap. That being said lets look at what you would need. I dont know of any turbo kits available for the Accord, so you will have to piece together your own. Turbo Manifold Turbo Intercooler piping Intercooler Custom downpipe Oil lines Engine management IMHO engine management is the most important part. K-pro is by far the best solution, but you should be able to use e-manage if you have to, and it is going to be a lot cheaper if you can find one. I dont know of any other good engine management solutions than those. Well, there is AEM, but it is more expensive. After that be sure to allow money to get it tuned. Good tuning will allow you to run safely, and not damage your motor. Improper tuning is a sure way to a blown motor. Im not a turbo guy, so anybody else feel free to chime in on the things Im sure Ive missed.
buntinboy9
Best bang for buck kit Ive seen for a f22 CD is the one by treadstone or vecco http://www.vecco.com/products.php?sub_cat_id=2
1994 Honda Accord w/ t25 set up @ 6psi
bigdaddyvtec
Re: Accord F22 Turbo
I spent less than 1k to turbo charge my car. Granted I already had a tuning setup and decent sized injectors.Whaxola09 wrote:It should be very possible to turbo that car. The problem is going to be money because I dont think you can do it on the cheap. But then I dont think you should do any major mods like a turbo on the cheap. That being said lets look at what you would need. I dont know of any turbo kits available for the Accord, so you will have to piece together your own. Turbo Manifold Turbo Intercooler piping Intercooler Custom downpipe Oil lines Engine management IMHO engine management is the most important part. K-pro is by far the best solution, but you should be able to use e-manage if you have to, and it is going to be a lot cheaper if you can find one. I dont know of any other good engine management solutions than those. Well, there is AEM, but it is more expensive. After that be sure to allow money to get it tuned. Good tuning will allow you to run safely, and not damage your motor. Improper tuning is a sure way to a blown motor. Im not a turbo guy, so anybody else feel free to chime in on the things Im sure Ive missed.
Perhaps you should travel to the UK and teach everybody how to tune?bigdaddyvtec wrote:Jesus i made more than 300/.300 on a stock f22b1 on crome with a t3/04e and ONLY headstuds in the motor. On a motor that had 140k on it. For over a year until my H was built. Meh...
bigdaddyvtec
Perhaps you should suck mah nuts12sec1/4 wrote:Perhaps you should travel to the UK and teach everybody how to tune?bigdaddyvtec wrote:Jesus i made more than 300/.300 on a stock f22b1 on crome with a t3/04e and ONLY headstuds in the motor. On a motor that had 140k on it. For over a year until my H was built. Meh...
750WHP 575 TQ Leed/eCtuned H22 CD5 Trick SLUT GFI: HOLLA!!! We build FAST
bigdaddyvtec wrote:Perhaps you should suck mah nuts12sec1/4 wrote:Perhaps you should travel to the UK and teach everybody how to tune?bigdaddyvtec wrote:Jesus i made more than 300/.300 on a stock f22b1 on crome with a t3/04e and ONLY headstuds in the motor. On a motor that had 140k on it. For over a year until my H was built. Meh...
