Cant select anything on the map while datalog is on? (FIXED)
cquence
Post by cquence »
Ok once I uploaded my .CAL on my ostrich I then switch the car KOEO and data logging enabled. Now I can not select any values on my maps. I tried highlighting values anywhere on the maps and ectunes automatically de-selects them for whatever reason. Loaded an old map from the previous tune, and this is still happening. any ideas?
cquence
Post by cquence »
Problem now (fixed!!) After still having the same problem mention above, I went ahead and started from scratch. Uninstall Netframe 3.5 and re-install a new copy Uninstall Ectune and re-install new copy followed by forced update. tested again. Loaded the CAL on the Ostrich after KOEO enabled data logging and now everything works like normal again. I can select/high-light any values in the table maps and they stay high-lighted. Now back to tuning:)
smart track was on smart track selects the cell where the ecu reads so you can just use the shortcut keys to adjust values. Useful for dyno tuning.
