Lists of bugs
- Synoptic
Lists of bugs
1. The VTEC map, when graph mode is enabled, will fill with \"blue\" cells as the trace gos trhough the map. It is NOT the smart tracking, but the actual cursor. 2. When graph mode is displayed, CTRL-J will stop working for no apparent reason. Even though I click back on the 2d map, CTRL-J will not work. 3. If I rescale the RPM, it seems that the core bin doesnt follow. I changed the 9000rpm row for 10000rpm, but when hitting 9000 RPM, it went to the 10000 RPM (it was 9000 RPM before) and skipped the 9000 RPM row. I was using r5 with 0.40. I would also like a way to go into \"graph edit mode\" and locking there without having to click on the grap map first.
working on the CTRL-J thing... Check the blue stuff... SO it does smart tracking on VTC map? if i understand good?
- Synoptic
No, it's not the purple smart tracking. It's the blue cursor (map trace) that colors the cell. Smart tracking is off when it does that.calvin wrote:working on the CTRL-J thing... Check the blue stuff... SO it does smart tracking on VTC map? if i understand good?
Re: Lists of bugs
I hope 1 and 2 fixed in the next release. Nick report back about 1Synoptic wrote:1. The VTEC map, when graph mode is enabled, will fill with "blue" cells as the trace gos trhough the map. It is NOT the smart tracking, but the actual cursor. 2. When graph mode is displayed, CTRL-J will stop working for no apparent reason. Even though I click back on the 2d map, CTRL-J will not work. 3. If I rescale the RPM, it seems that the core bin doesnt follow. I changed the 9000rpm row for 10000rpm, but when hitting 9000 RPM, it went to the 10000 RPM (it was 9000 RPM before) and skipped the 9000 RPM row. I was using r5 with 0.40. I would also like a way to go into "graph edit mode" and locking there without having to click on the grap map first.
