Cold start AFR's always changing............
Does not mater how many times I adjust ect and iat compensations, cold start afr's are always different from day to day. Specially when it's warm and I start the car. afr's tend to be at 17.5-18.0, and when it warms up, it's around 13.5. I've always had this issue. It was worse before, but after changing the iat sensor, it got a little better, but problem has always been there. I've adjusted compensations in any way possible, but no luck. Am I doing something wrong? Is anyone else having the same issue? Thanks............
Here's the latest cal. This one seems to be better, but still not very stable...
- new.calibration.code.16.fix.cal
- (8.19 KiB) Downloaded 335 times
Start a new cal from scratch and get the car started using the Injector Calibration tool in the tools drop down let the car warm and adjust battery offset. Let the car cool and then adjust ECT/IAT corrections. That's how I go about it and never have an issue. You adjusted the fuel table which is probably why it's not so stable.
