TPS died, now boost cut doesnt work?
My TPS failed recently and I noticed boost cut isnt working when I went to turn up the boost and overshot my limit. Does TPS have any correlation to it? Logs/Cal
ChrisStreetTune_Summer.cal
(8.19 KiB) Downloaded 199 times
newmap2.elf
(215.32 KiB) Downloaded 224 times
Confirmed it today. Set boost cut lower and it did not work.
MAde a new map and everything works now? I guess something bugged out on the other map.
correct.. boostcut is disabled based on tps and rpm when active
