Stock B18b T3/TO4E 14psi 308hp/269ftlbs
J. Mills
Post by J. Mills »
Bone stock LS motor T3/TO4E 60 trim Log manifold 3 inch downpipe and exhaust RC 550's Motorola 2.5 bar map sensor Tuned on eCtune Image
J. Mills Tuning authorized eCtune tuner (919)896-2532
J. Mills
Post by J. Mills »
Uploaded cal.
james-ectune-CRX.cal
Stock LS - 550's - Motorola 2.5 bar map - 14psi
(8.19 KiB) Downloaded 366 times
You revved a stock LS out to 8k?
J. Mills
Post by J. Mills »
ckretvix wrote:You revved a stock LS out to 8k?
The graph i posted does make it appear that way, but the highest rpm i took it to while tuning was 7600. The rev limit is set at 7400 i believe. Its in the cal file above. We have a optical rpm pickup on our new dyno at the shop. At the time of the graph i was using a rpm pickup method called "snapshot". It reads the rpm off the dyno roller. Sometimes it doesn't work so great. When using the optical rpm pickup on the crank or any other pulley on the engine it works wonderful. At the time of the graph i wasn't using it as i should. I wasn't tuning at the time either though. Although the rpm's are off in the graph the hp & torque readings are on point compared to when the rpm readings are right.
