This is really healthy engine i tuned yesterday. jdm h22a, 330cc, long tube header, 2.5 catback, clutch/flywheel, short ram. base pull graph from previous unknown tuner on crome: (super lean!) Final results eCtune dyno tuned graph: Car runs and pulls much better. Customer loves the difference.
im sure the customer loved the difference while going through the gears. 7700 will put you landing in the middle of the peak torque plateau in a stock geared h22. Pretty drastic amount of torque in that area from the base run. tuning ftw. Generally, what do stock h22's make on your dyno? range?
