just a question
just a question
if i record a log and save it, and then make a new map, and then play it over the new map, will the afr and est fuel change work on that map, i.e. playing the log file over the new map and make adjustments with out being hooked up to the vehicle? i was going to try a new cal. and was wondering if it worked that way to get a good starting point? thanks
ok never mind, it doesnt work that way
