Datalogs but not at idle...Injector Calibration issue
Just went out to start the car and try to diagnose a problem I have been having with idle anyways, when I let the car idle it won't log but soon as I touch the throttle it logs fine. I went through all the overlay conditions in the settings tab and they're all set low enough to where it should read/log at idle. I also noticed going into the Injector Calibration tool that hitting the +/- signs at the bottom would change Overall Fuel Trim and not the Injector Offset. Anyone else having these issues?
do you have the overlay set to overlay in gear 0?
jpjackson wrote:do you have the overlay set to overlay in gear 0?
Yep...I triple checked all my settings before I posted just to make sure I didn't miss anything.
WEIRD post a screen shot of your overlay tab so i can take a look. i had a weird problem a while back, mine wouldnt overlay at idle either, and i did somthing but i do not remember at the moment but i will try to. i was playing with the settings in the overlay tab.
should be a setting if it logs afr to grid in other gears
thats what i figured. make sure in the overlay settings you have gear 0 selected, if not it wont log at idle
I ran another force update when I made this post but I haven't tried it yet. Anyways here is the screen shot...
remove check fuelcut and try looks good though
VTEC Inside
Post by VTEC Inside »
May be a good idea to change the TPS to start from -1% or -2%. May be at idle ECU sees TPs under 0.
