update to be fixed by tonight!
Calvin was traveling all weekend and is sick. He says he will fix the update tonight. thanks for your patience.
^^ Not for me unfortunately.
Whenever I try forced update it just says it's up to date with the .3r10 version instead of .2r11. Got and email back that said this: Update methodes: *Force update: Use force update from the start menu(start->ectune->forceupdate) *Rar update: download in ectune directory and extract it in the root) ectune.update.current.rar *Full installer: Remove previous version and download and run installer ectune.setup.current.rar Still no worky with any of those.
did you try opening the program? it did the same thing to me but after force updating twice i tried opening the software and it did and it said 2.3.r11 so it did the update and i am back in. so try opening the software anyways, even though it say 2.3.r10HighBoostCreative wrote:^^ Not for me unfortunately.Whenever I try forced update it just says it's up to date with the .3r10 version instead of .2r11. Got and email back that said this: Update methodes: *Force update: Use force update from the start menu(start->ectune->forceupdate) *Rar update: download in ectune directory and extract it in the root) ectune.update.current.rar *Full installer: Remove previous version and download and run installer ectune.setup.current.rar Still no worky with any of those.
try force update again and then thy to open the program. if that doesn't work i dunno. would your one year license happen to be expired? in that case you need to request a new license.HighBoostCreative wrote:Done it. No luck.jpjackson wrote:did you try opening the program? it did the same thing to me but after force updating twice i tried opening the software and it did and it said 2.3.r11 so it did the update and i am back in. so try opening the software anyways, even though it say 2.3.r10
i am back up and running, where is the update list for what was fixed? was the normally open and normally closed for the ebc fixed?
I guess only expire date was "fixed". Every new release I wonder if it's now that: -Demon onboard logging gets implemented -"something no other EMS has..." gets implemented toojpjackson wrote:i am back up and running, where is the update list for what was fixed? was the normally open and normally closed for the ebc fixed?
why the heck would i do that?elevation wrote:hook up a bulb and CYAjpjackson wrote:i am back up and running, where is the update list for what was fixed? was the normally open and normally closed for the ebc fixed?
