243WHP 8:1Cr B16a
b20beast
243WHP 8:1Cr B16a
Post by b20beast »
Tial 38mm Wastegate Ebay Cast manifold Tial Bov 880cc injectors Walbro 225 spooling performance intercooler pipe. 2.25->2.5\" Precision 350hp intercooler garrett t3 t4 60 trim .63 type r cams. Image Image Image Image Can anyone tell me why the torque is dropping off so hard up top?
Civic VTI-Turbo
Post by Civic VTI-Turbo »
How is the boost? Is it stable?
b20beast
Post by b20beast »
Civic VTI-Turbo wrote:How is the boost? Is it stable?
i attached a pic with the boost log...
EITCP
Post by EITCP »
what kind of turbo manifold you have?
b20beast
Post by b20beast »
EITCP wrote:what kind of turbo manifold you have?
Its a cast manifold.... like a ugr cast racing manifold Image only mine isnt jet coated
send me your map I'll make changes and send it back..
or post it here..
b20beast
Post by b20beast »
Thanks buggermass!
6 degreessmooth.cal
Map!
(8.19 KiB) Downloaded 749 times
I'll dl and clean it up a little tommorrow.. Do me a favor and do a 3rd and or 4th gear pull if you can on a fresh set of plugs then take a pic and post it.. I need to see the ground strap.
b20beast
Post by b20beast »
Bugermass wrote:I'll dl and clean it up a little tommorrow.. Do me a favor and do a 3rd and or 4th gear pull if you can on a fresh set of plugs then take a pic and post it.. I need to see the ground strap.
what are we looking for? DET or AFR?
timing reference.
b20beast
Post by b20beast »
Bugermass wrote:timing reference.
Do you think theres a flow restriction? boost leak or smtn?
try this.. Keep an eye on your fueling I made some small changes. it should feel wayy smoother, but I'm pretty sure this is still conservative for the compression your running. also.. be SURE your timing is synced properly. lemme know how it goes. if you throw in a new set of plugs and do a couple runs then pull them and take pics I can help you get this thing dialed in.
Adjusted Map.cal
(8.19 KiB) Downloaded 787 times
You give free tuning over the Internet now??? >XD
Civic VTI-Turbo
Timing looks much better now Burgermass....
