Ostrich serial resetting.... very odd.
So Calvin; as you may have seen, I have requested a new ostrich license.... same ostrich... I had switched (in the last version) from eCtune to no vendor so I could use an OEM ROM on my vehicle to initially smog it as I have zero driving time on this car. When I went to use eCtune to check some sensor data, I loaded it and my serial was all \"F\"'s.... in a manner of speaking I got F-ed.... lol My ostrich has not been reset via batteries, or anything else for that matter... I really am clueless as to how this is happening as I never had an issue in the past. I am afraid to de-vendor my ostrich and try using CROME to do what I need to do... because the license may reset itself causing more work for you... IDK, maybe I am paranoid. I will admit, that previously (right after getting my; what was; current license), I have reset my ostrich using your ostrich reset utility (download-able in the forums) and I checked previously to make sure the serialID had not been changed... But there is a lingering thought in my mind that somehow this may have caused it? I use this utility because on this old T21 laptop, it loads way faster than eCtune =) I can understand your need to disable the previous emulator and verify registration before sending the new license... so that doesn't upset me.. though it would be nice if it was instant as the first ostrich serialization license is =) Any thoughts?
I will; I thankfully got my car through emissions yesterday, and got my new plates, so I will run out with the laptop trying a bunch of things; the first thing I want to try is a double reset of vendor thru the reset app.... Then work my way down what was done with the ostrich between the first and second license
I've always been good at finding the method, I have my fingers crossed for this one
. Not a fun bug for anyone; yet I find the odd ones
