+1 ectune changes results dramatically.9400RPMS wrote:OutSTANDING gains.. Cromepro isn't a bad product for a mostly stock tune or a basic bolton setup.. when you get more in depth like turboing, it becomes less steller a program to use.. I've used alot of products, i'd say ectune is the best by far..
Like we discussed last night, Crome's timing values are alittle iffy, when they were supposely running 21 degs wot at 17psi, they were really running 35ish you know? lol.. I stick to what i said.. =)Bugermass wrote:heh, I don't know what timing values he used. I can't really comment on his tuning.. either way I made more power.. Apprantly this was the second motor, the previous motor they tried to turn up the boost more and blew the motor. Funny since I did 26PSI on the same turbo setup on the new motor with no issues other than a slipping clutch.
I thought that was fixed in some of the newer versions. My personal experience has been that I have no problem taking out timing. I tried this on a car recently and I could really tell a difference. I pulled a buttload of timing out of a boost map to see if it would run like crap. It did. Next test I did was to tune the car normally at a set PSI then take out timing from the last used boost column I was on. Well I did that and the car turned into a turd. This is just my experience and I know that there can be other variables. On topic though, eCtune kills crome in ease of use and less bugs.9400RPMS wrote:Like we discussed last night, Crome's timing values are alittle iffy, when they were supposely running 21 degs wot at 17psi, they were really running 35ish you know? lol.. I stick to what i said.. =)Bugermass wrote:heh, I don't know what timing values he used. I can't really comment on his tuning.. either way I made more power.. Apprantly this was the second motor, the previous motor they tried to turn up the boost more and blew the motor. Funny since I did 26PSI on the same turbo setup on the new motor with no issues other than a slipping clutch.
