Lean protection not working right?
dbsharp
Post by dbsharp »
Edited to prevent the spread of misinformation... Basically; When both lean protections are enabled, car runs like shit wont rev at all and flashes cel light untill. eventually cel stays on and car runs even worse.
F22B_HE-341_3BAR_WRX_INJECTORS 1.5.cal
(8.19 KiB) Downloaded 165 times
dbsharp
Post by dbsharp »
Ok I figured out what is causing this. This only happens when I try to add in the 2nd lean protection. If I just have the 1st lean protection I don't get the problem.
dbsharp
Post by dbsharp »
Hello ............Hello ............ Hello ............ Hello ............ Hello ............ Anyone in here these days? Anyone else having this issue? Any chance I can get both lean protections working?
At one point I had them both working on my own race car, unfortunately it´s not running at the moment so I can´t re-test here for a long while. /Allan
This has been a problem forever. Secondary lean protection has never worked for me and sets a rev limiter at whatever you set the condition at.
DSMR
Post by DSMR »
Verified that this does not work. Any help out there with this? or is this going to be another advertised output that does not work properly?
