JRSC B20B 200hp 160tq
Natural Aspirations
Post by Natural Aspirations »
N/A 164/134 Image 7PSI 205/160 Image Stock Block B20B Head Milled 0.030\" Crower 403's S2 Header 2.5\" exhaust 65mm TB B16 M62 JRSC fitted to the P75 head ID725 Injectors First boosted tune on eCtune. Attached the .cal and a short datalog from an autocross. Any advise would be great, engine is currently being rebuilt and will be retuned for spring.
8.08.10 smooth.cal
(8.19 KiB) Downloaded 726 times
run 4 5.9_09052010_1052.elf
(551.01 KiB) Downloaded 676 times
Graph looks great, Smooth those fuel maps and revise those timing maps. See how your pulling timing towards redline? Your going from ~27 degrees to 25 degrees, thats backwards and will cause your car to 'nose over' so to speak. You should be adding timing as the rpms progress.
Natural Aspirations
Thanks! For some reason I thought you were supposed to pull timing after peak Tq. I wish I remember where I read that....
Natural Aspirations wrote:Thanks! For some reason I thought you were supposed to pull timing after peak Tq. I wish I remember where I read that....
VE decreases after peak torque so fuel requirements go down to acheive same AFRs As RPMs increase, there is less time for flame propagation so timing needs to advance
Natural Aspirations
Makes perfect sense..... Probably could have carried a little bit higher, it's apart now on to the next project. Thanks for the tips guys!
