Boost Cut and EBC Problem
rich777
Post by rich777 »
Hey guys Can someone take a look at my map and datalogs please and tell me where i'm going wrong. I keep hitting boost cut for some strange reason. Also my EBC seems to be work backwards and i'm positive i've got it setup properly (100% DC = WG pressure 0%DC = Full boost) . Is the way i have the ebc setup in the pictures below correct ? Thank you all for your time Richard Image Image Image
Rich.cal
(8.19 KiB) Downloaded 238 times
Rich 7psi.elf
(186.99 KiB) Downloaded 257 times
Rich 9psi boost cut.elf
(89.63 KiB) Downloaded 287 times
4thgenhtch
Post by 4thgenhtch »
Hey I`m richard too :D Yes your vacuum is setup right, I was having the same issues theirs a glitch in the program, switch NO to NC or vice versa in the software... and go from there map out your duty cycles, for your look up tables and then you can fill out your boost by gear tables from that... http://forum.ectune.com/viewtopic.php?t=2871
<img></a>
rich777
Post by rich777 »
Ha Ha, :wink: Hows it going ? Thanks for that i'll give it a go at the weekend. What about the boost cut problem ? Can anyone explain why i'm hitting boost cut ? Thank you :roll:
rich777
Post by rich777 »
Anyone ? :(
rich777
Post by rich777 »
Is where i'me getting the power supply from ok ? Its coming form the distributor. Thank you
4thgenhtch
Yea from the dizzy is fine, Whats your cut set to? So you cant get the boost to regulate? Take the line off the wg and blow into it and make sure its venting from the filter on the side...
<img></a>
rich777
Post by rich777 »
Sorry for that late reply. I have sorted this now. I just started a new map and i don't seem to have a problem now. Strange......
92redhatch
Post by 92redhatch »
Set your ebc to normally closed. And start at 0 psi
rich777
Post by rich777 »
Thank you, i'v sorted it though...
