B16B 1.8ltr Jun3 250 CHP - 222WHP
Image Engine: B16b (1820cc, 81.5x87.2mm) Wiseco 12.5 cr race prep pistons Manley H beam rods ACL race bearings B18c type R oil pump B18c type R water pump B18c type R ported cylinder head with full radius valve job Supertech nitrided valves, valvesprings and titanium retainers Jun type 3 camshafts with Skunk2 pro camgears RMF narrow header 2.5�-2.75� test pipe with flex pipe Kakimotor R 2.75� catback Edelbrock Performer X intake manifold (ported) Professional products 76-68mm throttle body 3� intake with BPI flow stack, filter and airbox RC 370cc injectors Walbro 255lph fuel pump B18c type R ignition rotor NGK Iridium IX BKR7EIX-11 spark plugs NGK spark plug wires Gates Racing timing belt Gates Racing low temp thermostat Godspeed ITR DC2 full size radiator with 12\" slim fan Spoon radiator cap Custom breather tank system Avid Racing polyurethane engine mounts Racimex oil cooler Torco SR5 5w50 motor oil and MPM G12 coolant
Vtec6000
Post by Vtec6000 »
Nice 8)
Garrett
Post by Garrett »
I always love JUN3
utkuselamoglu
Post by utkuselamoglu »
I have used jun type 3 cams with b20 vtec and almost I had 250 hp... You have very good numbers... But I think jun offers jun type 2 valve springs and retainers for type3 cams only.
utku selamoglu
Same engine, other dyno. This time a US style Dynojet. Image A whopping 222 WHP!
FreshDA9
Post by FreshDA9 »
very nice. im working on a Hi compression big cam B16 and need some help with a good start in the timing map. would you mind posting some screen shots of the timing table.
Garrett
Post by Garrett »
14:1 WOT, is a little bit lean :lol:
FreshDA9 wrote:very nice. im working on a Hi compression big cam B16 and need some help with a good start in the timing map. would you mind posting some screen shots of the timing table.
I got it on my laptop, give me a few days and I will post the .cal
Garrett wrote:14:1 WOT, is a little bit lean :lol:
I think this wideband must be way off. hardly possible to make this kind of power with 14:1
FreshDA9
Post by FreshDA9 »
Thank you. im mainly interested in idle ignition for big cam cars as of right now. i looked threw a lot of cals and noticed most sit at stock 16.5 degrees at idle. my mentor said
A motor can only pull so much vac depending on the cam. You keep adding timing until you stop seeing an increase in vac. No point in adding more timing if the vac does not change.
i ask this because i have this b16 in high 40's at idle and i feel im doing something wrong, i kept adding timing and it kept getting lower in KPA. it does have crower stage 2 and 3/4 cams and valve train. My biggest issue is timing as i feel i still dont understand other then what the dyno can tell me after pulls. I do read plugs but not as often as i really should.
FreshDA9 wrote:Thank you. im mainly interested in idle ignition for big cam cars as of right now. i looked threw a lot of cals and noticed most sit at stock 16.5 degrees at idle. my mentor said
Idle ign is like stock at 16,5 degrees. runs fine.
.cal from this monster. Enjoy!
Rick-ect.0065-rev10kortepijp.cal
(8.19 KiB) Downloaded 1265 times
9400RPMS
Post by 9400RPMS »
reason why you have a b10 / b11 col?
DDTech | DDTECHCAMS.COM
Just to be safe. With this kind of engine, I always activate the 11th column to be sure that if it reads from this 11th column it reads the right values. I thought Calvin made something to avoid wrong readings but I just want to be sure.
9400RPMS
Post by 9400RPMS »
gas, can you tell me how you added a 11b col?
