513whp LS, 93 oct
513whp LS, 93 oct
84mm Benson Block CP 9.7:1 Pistons Eagle Rod Crower 404 and springs/retainers SFP Mani Victor X STC 62mm Reaper 3inch DP, 4 inch Exhaust NGK 5238 plugs (9's) 15lbs - 368hp/268trq 20lbs - 435hp/311trq 30lbs - 513hp/366trq Image Exhaust manifold and head are def. hurting me but the car is a beast
92redhatch
Post by 92redhatch »
Great powerband. 500Whp is a lot of fun
Yeah its great at 15-25psi. 30psi was just to see what we could do with the stock head and log manifold lol.
92redhatch
Now that you know the motor is making power without issues put a bigger turbo on there and go for more power
Turbos big enough. Its 64 lb/min. The exhaust manifold and head is holding it back
Good job! You should post the cal file and some pictures of the setup!
civic_tune_2011.cal
(8.19 KiB) Downloaded 812 times
12sec1/4
Post by 12sec1/4 »
Love it! 8) I have 343bhp on tap (ATF) and I have plenty of fun... I really can't imagine how this thing pulls! I can't plant the pedal in 2nd gear as I just spin up.. 3rd hooks but if it's cold outside it will spin the wheels! How is your traction on the road? Is this a road car or built for racing ? Paul. :)
http://www.youtube.com/watch?v=-V-DmLIvwdI Its \"built\" for drag racing
Tune appears to be protected or corrupted.
