closed loop gub
closed loop gub
!erehT iH I've been having a lot of problems getting the low throttle stuff tuned so I tried enabling open loop to see if it could correct anything... I found an interesting bug. Using the .44 rom I enabled open loop on a really lean idle mixture. It started around 20:1 AFR and slowly the fuel trim increased bringing the mixture as low as 15.5. Then the fuel trim value wrapped back to \"0\" and the process repeated itself. Steps to reproduce this problem... Create a base map on any given car that still has the O2 sensor installed. Enable closed loop operation and remove some fuel from the idle part of the fuel map. Watch as the O2 trim goes up until it wraps around. -Michael
