4 port boost solenoid possible?
joppez
http://www.evans-tuning.com/ecommerce/b ... enoid.html I think it will run with ectune but anyone use it yet? Is this mac solenoid allso and can it found somewhere else cheaper? I paid like $30 my 3 port mac solenoid, and its maxing out 27psi with 12psi spring.
stenseltizm
you can buy MAC products from your local automation and supply company. The difficult thing is going to be working with them to track down a suitable valve as they have plenty of options. If it's not a commonly used valve that they have on their shelf, be prepaired to wait for 4+weeks to get it from the factory. Edit: Didn't realize you were in Finland, but MAC still lists a vendor Lektar Oy P.O. Box 92, FI-00710 Helsinki Hiekkakiventie 7 FI-00710 Helsinki 358 09 413 55 100 fax 358 09 413 55 120 lektar
I think its this http://macvalves.com/valves/4-way-valves/46-series/ I found at HT this:
Im running 31hz now so i have room to lower it. I might test it first because i dont need much more than now.try lower frequencies to get more boost out of it
