Idle consistency errors with .44
Joey Misanthropy
Post by Joey Misanthropy »
Both the cars I tuned Saturday displayed some small idle errors. The Prelude had it's idle speed increase a little mid-tune. There had been a problem with the car's radiator cap not pressurizing the system and this could have been caused by coolant level or an air bubble purging itself. I have no updates on the car's idle as of now. The B16 hatch has confirmed idle problems. I experienced it on the dyno and during the testdrive afterward - idle speed would drift high/low as the day went on, and idle AFRs would sometimes go lean (mid-high 15's). It did this with closed loop disabled, and it is still doing it with wideband closed loop enabled. Find attached the .cals for both cars, and a cellphone video of the B16 hatch's idle that should play in VideoLAN (among other media players).
Mike Idle.rar
B16 hatch idle
(192.2 KiB) Downloaded 272 times
I need log files.. much more important
Joey Misanthropy
The vehicle owner has emailled you about a logger version - he already has a wideband wired to the ECU, etc.
Ok.. i'll give u a call tomorrow
