HELP trouble starting and idle !!!
jcl
Post by jcl »
Hello everyone I'm new to this forum, I just buy ectune, but I have trouble getting the engine to start and idle. Leave some specs of what drives my engine. F22B1 Vtec Full Forged Internals RC 1000cc at 60psi GM 3bar map Precision Turbo 6262sc I can not get the engine pump.The nor that they remain at idle, starts as a 3-cylinder and half maintained but stops, problem if compensation cranking/poststartup or compensation injectors boot, have if I can lend a hand. The engine has made ​​break-in with crome and goes perfectly, so here is no mechanical failure. I leave the calibration I'm using. Thanks in advance. I await your response.[/b]
Accord F22 Vtec Turbo 1000cc.cal
(8.26 KiB) Downloaded 214 times
civicek36
Post by civicek36 »
I emailed you... let me know
