0.0.2.0 r0 bugs
hackish
0.0.2.0 r0 bugs
Post by hackish »
Think I got the version number right... I tried tuning a customer's car today and found a few small issues. Ultimately we were not able to complete tuning due to a completely different issue so I didn't get that much time... In the fuel graph the dropdown for acceleration is spelled wrong. Using shift and the arrow keys to select cells in the graph display (for example select the boost section of the table) is extremely slow. On a 1.6ghz machine it was taking about a second to select every row. Deselecting it makes the program unresponsive for about 3 seconds. Show peak values in the display window does not appear to do anything. If you change the map sensor unit from mbar to PSI with the fuel graph being displayed you have to close ectune and then re-open it in order to have the column labels change from the default mbar to PSI. I selected the activation type for the boost controller to always on but it did not appear to take this selection as I went back to it later and found it disabled again. Wasn't able to spend much time figuring out exactly what was going on though... -Michael
i'll check on that... SHow peak didn't work, ebc always on... weird let me check what's going on
calvin wrote:i'll check on that... SHow peak didn't work, ebc always on... weird let me check what's going on
In the EBC window...when you change mbar to PSI and vice versa...sometimes those settings dont stick. When you graph "EBC Current" it is always displayed at MBAR...no way to get it to read in PSI Also, cranking multiplier likes to change itself back a lot.
-EBC activation input is working -Show peak values displays peak in datalogging display Will look at: Ebc Current Mbar-PSI change change Spelling Accel. Shift Keys Xenocron: - Just change the cranck trim 20 times switch from tab every time and it saves. When are you guys having problems with inverting values? Can you save the rom change the crank trim and then see if modified is red in the status bar?
Re: 0.0.2.0 r0 bugs
hackish wrote: Using shift and the arrow keys to select cells in the graph display (for example select the boost section of the table) is extremely slow. On a 1.6ghz machine it was taking about a second to select every row. Deselecting it makes the program unresponsive for about 3 seconds. -Michael
It isn't so slow here.. It's due to the way i'm doing selection i think. I'll have an other look again how it can go faster.. Maybe seperate thread with high priority
hackish
Post by hackish »
Maybe look at the algorithm. Perhaps it is redrawing everything when you select cells, so if there are 25 cells selected it redraws 25 times or something slow like that. It's a laptop with a not very fast graphics card. -Michael
All reported bug fixed. Only the shift select in graph mode
