I dyno'd a buddys gsr coupe today, ,Je pistons,eagle rods, stock sleeves, 750's, drag style kit, some t3/t4 car, made 380hp 305 tq on 18lbs on pump(no smoothing added), we decied to stop there on 93.
So we threw a 75 shot(wet) and throw in some race gas on top of his 93, car made 522hp 420ish tq. so picked up 140hp 105 tq from a 75 shot. The plugs were clean as whistle. I think like with Mr. Davis' last posted dyno, the turbine side got maxed out where you see the dip at 7k rpms. I don't don't know which wheel it is though(i'm assuming it was a stage 3 wheel ,it had a .48 housing, which is why tq seemed to be falling off, i played with the timing a bunch, the tq just wouldn't hold flat) I do know that i'm really starting to like this spray and boost stuff. I've been trying to figure how/way some boosted cars are making such big numbers on spray and some are making what the shot is, I'm sure some of its due to lower intake temps, but i have a lot of whys that i want to get figured out. Any one else have any ideas?? Sorry for the shitty scans and the lower rpms getting cut off, i need to save them from the dyno.
