Est. Fuel Change overlay doesn't clear
In the fuel table, When I select \"Est. Fuel Change\" from Overlay selector and datalog some, the cells that I hit are highlighted with data and other cells are blank. When I then click on \"Clear map trails\" the chart doesn't reset or clear. I think it should. Am I wrong on this?
thank you borrat. You have clear all recordings CTRL+C Map trails.. You can trail when making a run where your trace have been. If you use that with rpm vs AFR you can see where you have to adjust
