WideBand settings (EGR lift on D11 - should be D12)
Orthello
Post by Orthello »
Not really a bug, but can cause problems when not mentioned... eCtune Single Car Pro version 0.0.2.0 r6 In the \"eCtune Settings\" window on the \"Wideband\" tab ther is a block with four radio buttons on the top right. These radio buttons are use the select the Wideband input. This is what is currently there: ELD Input (D10) B6 Input (B6) O2 Input (D14) EGR Lift In (D11) As far as I know D11 is TPS, which should most likely always be used for.... TPS :D EGR Lift In is D12 Just wanted to mention this.
See the red circle. D11 should be D12  (IMO)
wil fix boss
Orthello
Post by Orthello »
ok.. employee 8)
fixed
