Secondary maps triggered by analog input?
HiProfile
I was looking to utilize Crome+Ecutout+2timer to have a map for full exhaust and a map for the Ecutout. Now if I go with eCtune Pro, will I be able to all of the following at the same time? *Use the EBC via EGR (can use IAB if needed) *Trigger a relay via an output (TPS based?) *Go to secondary maps when the output is triggered (TPS based?) I seem to recall reading that when using the EBC (one of the outputs), you can't use other outputs - or was that just for MBC? I'm hoping those features are even implamented at this point
I'm really hoping to do this all w/o mechanical switches or relays off the TPS - its already mechanical enough... Its a custom E-cutout that's cable-opperated via a heavy-duty solenoid (extremely fast).
DIY won't have Secondary maps and EBC. What you requested can be done. GPO active on x tps(enables output if you want) and switch to secondary maps
