Custom Gear ratios
Custom Gear ratios
Which user has custom gear ratio's?
sasquatch
Post by sasquatch »
i plan on changing the final drive in the not so distant future. but as of right now stock ls for me
i have because my car isn't listed EUDM Civic MB6 4 doors with LSD you sent me XL calcuation page
You have eCtune running right? Does you gear display in eCtune match the gears you are in?
I can't be sure because didn't look at it very carefuly i'll give a try and post the result tomorow morning regards
important drive through all gear and see if you gear in ectune is same as actual
A good way to check is do a log where you tap the top of each gear; you will see if the gear value changes prematurely in the log.... I noticed this once, and then realized that I forgot to change rom the S80 tranny to the S20 model.
I tried this morning in the way for work i seems to be good, just when i stay to much time between gear display show me the fifth gear
dav_02062008_0926.elf
(1.45 MiB) Downloaded 296 times
that is normal can you post your call too pls?
Calvin here my calibration it's a tempory one NA, i've just removed the JRSC for porting and wait for my LHT manifol
B18ATMO.cal
(8.17 KiB) Downloaded 306 times
