Small Checkbox Bug (Anti-Lag Ignition /Enable)
BlindFashion
Open eCtune, Open rom, go to parameters, go to anti lag Under Anti-Lag Ignition Control the enable checkbox won't stay checked. It will until you change to a different menu and then come back it will be unchecked again. I have yet to test it in the car to see if the anti lag still works. I've attached a picture to show you -Josh
BlindFashion
And then if i un-check and check the static ignition value checkbox it does this (attached picture) (like normall) and then if I switch to a different Parameter menu and go back to anti lag it repeats the same enable checkbox bug. I even tried saving before changing menu's and it still happend.
couldn't reproduce here testing more. i test in tuner and pro version as soon as i check it.. you see modified on the bottom change parameter and going back shows a checked box
BlindFashion
Just wanted to add that I just came across this as well. I was editing my Anti-Lag settings and it greyed out the Enable check box, Static Ignition box, and the apply to final ignition box (might have already been greyed). Closing and opening eCtune ungreyed the static ignition box, however, changing the number resulted in it being greyed out again.
can u post exact steps to reproduce the bug.. i check quickly and couldn't find any.. please post exact steps from opening a cal to producing the bug
I'll try to be as detailed as possible but I found this after playing around with my tune for about an hour so I won't be able to tell you everything. 1. Open CAL file 2. Start Emulator 3. Start Datalog (automatically starts recording) 4. (After driving) Stop Recording, Save file 5. Open Graphs 6. Change values based on graphs 7. Open Parameters window 8. Click on every single menu item on the left (I was making sure nothing was set wrong) 9. It happened when I got down to the Anti-Lag menu. I clicked on the first timing value, changed it, and hit tab and that's when it greyed out on me. Hope that helps.
stenseltizm
I can reproduce the bug easily. -Open ectune, not hooked to ostrich or ecu. (auto-opens last rom) -Open parameters window, highlight Anti-lag on left -check 'Enable Anti-lag' at top. The box under 'Anti-lag Retard Ignition Control' is instantly checked but stays greyed -select any other parameter on left then go back to Anti-lag. -Check box under 'Anti-lag Retard Ignition Control' is unchecked and stays greyed. -Uncheck 'Enable Anti-lag' and the box under 'Anti-lag Retard Ignition Control' is instantly checked but stays greyed -select any other parameter on left then go back to Anti-lag. -Check box under 'Anti-lag Retard Ignition Control' is unchecked and greyed out.
BlindFashion
