program loading error
i get a microsoft error when i try to open ectune. Error signature: EventType : clr20r3 P1 : ectune.exe P2 : 0.0.2.2 P3 : 48fd1f83 P4 : system.configuration P5 : 2.0.0.0 P6 : 471ebf00 P7 : 1a8 P8 : 4d P9 : ioibmurhynrxkw0zxkyrvfn0boyyufow I have a race tonight!!!
I have tried rebooting, running spybot, CCcleaner, force update (gives me an error that it cannot find base_roms) and i have updated windows.
ran spybot search and destroy again and now i can get it to partially load ectune. During the \"checking for updates\" phase and loading settings, it tells me it could not parse or find the settings file. Then closes ectune and gives me the windows error again.
- utkuselamoglu
there could be some problem with the settings files under your "c:\\program files\\ectune" folder. Maybe your "settings.xml" file corroupted. In this forum there is a post talking about your issue. In that thread shows how to reinstall ectune by deleting some files under ectune folder. I am not sure also.98vtec wrote:ran spybot search and destroy again and now i can get it to partially load ectune. During the "checking for updates" phase and loading settings, it tells me it could not parse or find the settings file. Then closes ectune and gives me the windows error again.
utku selamoglu
calvin can you confirm that i need to delete settings?White_Teg wrote:I think Calvin ment for you to delete the settings.xml file. I would guess that somehow this file is getting corrupt. When you run eCtune after deleting it, it most likely creates a new one with the default settings.98vtec wrote:i still have my settings folder and setting XML file.
?98vtec wrote:calvin can you confirm that i need to delete settings?White_Teg wrote:I think Calvin ment for you to delete the settings.xml file. I would guess that somehow this file is getting corrupt. When you run eCtune after deleting it, it most likely creates a new one with the default settings.98vtec wrote:i still have my settings folder and setting XML file.
from This Thread
calvin wrote:uninstall/reinstall do a force update... delete this too.. C:\\Documents and Settings\\<username>\\Local Settings\\Application Datafolder In4Tec_Solutions <username> your current login name
thanks, i'll try that tomorrow when i get on campus.White_Teg wrote:from This Threadcalvin wrote:uninstall/reinstall do a force update... delete this too.. C:\\Documents and Settings\\<username>\\Local Settings\\Application Datafolder In4Tec_Solutions <username> your current login name
woops
I uninstalled ectune and then reinstalled with the original setup function then use force update. opened ectune and got this error
