still lean
vtecmangr
still lean
i am having some problems with my bin running ectune on a turbo gsr with pistons rod combo my car is leaning out after 0,6 bar turbo is master power st70 p trim in70 ex96ar 650 siemens deka walbro 255 bennen fuel rail distributor is brand new ordered some 650 presicion injectors but xenocron send me some siemens deka the problem is that with crome gold bin tha car is running very good,no leaning issues so i am guesing i do something wrong i will order some 1000cc injectors just to try but please see in my map if there is something i didnt get runs in idle very well just all the map is rich just when i hit 0.6 it gets lean and whatever i do to the boost portion place this situation dont change thanks in advance
- arxiko5.cal
- (8.19 KiB) Downloaded 390 times
Re: still lean
just so you are aware, the Precision 650cc (High Imp) are Seimens injectorsvtecmangr wrote: ordered some 650 presicion injectors but xenocron send me some siemens deka
Re: still lean
i didnt said that the injectors are the problemxenocron wrote:just so you are aware, the Precision 650cc (High Imp) are Seimens injectorsvtecmangr wrote: ordered some 650 presicion injectors but xenocron send me some siemens dekaHop back online, Im on MSN right now
first of all. you have fuel values of 6000 FV. that is not good. I would recommend starting with a new map. tuning the car below boost esp. column 10 and run the boost table setup fuel 120% over it.
- arxiko5.cal
- modded
- (8.19 KiB) Downloaded 373 times
no,no BM fuel regulator,so yes even with this amount of fuel was lean also the fuel pressure at idle is 4 bar and at wot 5 bar i didnt try the map cause i dont have the car right now living in a diferent country i will also try a new wb with the new rc's that i boughtGaskleppie wrote:Still lean? Do you have a B&M fuel regulator? I have seen at least 10 of them broken with these kinds of problems as a result.
Only thing i think of. Fuel pump maybe a Chinese Walbro? Or a broken FPR. I think fuel pressure is dropping at certain boost. e.g. Base fuel Pres+Amt(full throttle) Press+boost so 42 base pres psi with hose disconnect 40 pres psi with hose connected(idle) 42+7(psi boost) = 49 psi. Something most go wrong. Maybe run a line from gauge(inside car) to fuel filter to monitor FPR under boost.
i will try this aso and bring a fp gauge into the cabin also the walbro is boughted from chris so i dont think its a chinese one as soon as i go back to the car i will try all these you have posted thankscalvin wrote:Only thing i think of. Fuel pump maybe a Chinese Walbro? Or a broken FPR. I think fuel pressure is dropping at certain boost. e.g. Base fuel Pres+Amt(full throttle) Press+boost so 42 base pres psi with hose disconnect 40 pres psi with hose connected(idle) 42+7(psi boost) = 49 psi. Something most go wrong. Maybe run a line from gauge(inside car) to fuel filter to monitor FPR under boost.
