ECT/IAT Corrections working for everyone?
Was messing around with my tune I went to adjust ECT corrections and notice my A/F ratio wouldn't change no matter what value I put in. Take a look
- ECT Correction.JPG (199.02 KiB) Viewed 21941 times
- Corrections.JPG (199.12 KiB) Viewed 21942 times
- yc underground
I've also notice this issue.
Did some testing today, everything worked for me except ECT fuel compensation. In the logs you can see everything work except for the ECT fuel comp. The part of the log from about 50 seconds - 1 min 45 seconds is when I was trying to get it to do anything, I tried random numbers from 1-90 and nothing changed.
- iat ect test.elf
- (565.4 KiB) Downloaded 948 times
- tne after dyno 28 and 9s in march 2010.cal
- (8.19 KiB) Downloaded 976 times
The corrections work fine. The issues is that stock honda code only updates ECT values every couple minutes it seems. so you won't see an instant change. If you keyy of then back on your values will update. I talked to calvin today about trying to shorten the update timer for ECT values so you guys will stop freakin out..
I use the corrections on every setup that flys outta here. I tweak start up fueling, correct for heat soak, compensate for outside temp changes, etc.
It hasn't changed for you, the corrections also haven't stopped working for you either but corrections don't work for me. I made some changes again to the corrections today, drove to a friends house got there and didn't log any correction. Turned the car on went home still didn't log any correction. Don't know what else I can say.
