Datalogger won't connect to ecu/Fixed/Hulog cable wrong
OneRM
Post by OneRM »
Ok, so i just got everything setup. Did my ectune update, did my ostrich update, updated my usb ports. Everything is working and I've loaded a basemap however the datalogger won't connect. popup says can't connect to ecu.
make sure j12 is cut. Check in device manager which port your datalogging uses.(don't plug in your ostrich). Now that you have the right comm port open settings->datalogging Disable auto-scan Select correct comm port Baud 38400 And press test
boostedeh2
Post by boostedeh2 »
my datalog won't connect unless the key position to \"ON\"...Don't know if that would help.
zex_cool
Post by zex_cool »
that is how it works. key on; datalog on...key off; datalog off.
ecu is off if key is off :shock:
boostedeh2
Re: Datalogger won't connect to ecu
OneRM wrote:Ok, so i just got everything setup. Did my ectune update, did my ostrich update, updated my usb ports. Everything is working and I've loaded a basemap however the datalogger won't connect. popup says can't connect to ecu.
yup, did you turn your key on when you were trying to connect?
boostedeh2
OneRM
Post by OneRM »
tried with key on and car running, both no go. I'll check j12 to make sure its cut, that may be the problem. I'll keep you posted.
hard set the comm port and the baud should be 38400
OneRM
Post by OneRM »
cut j12 and changed to com port 5, with 38xxxx baud setting. Still no change.
if you key on how many flashes do you see?
OneRM
Post by OneRM »
how many flashes? where would it be flashing. I don't see any flashes on CEL or in software.... Thanks for the speedy responses btw.
If you have uploaded a basemap when you put the key in the on position your CEL will light then go out, this is where you need to pay attention, the CEL will flash again shortly after the CEL goes out.
Pay close attention what u see and hear if u key on. And let me know. Did you do upload base+calibration?
OneRM
Post by OneRM »
just did basemap+calibration. still no dice. I do however see 3 flashes if that helps?
